Scubadave16
I have a 1996 Sea Doo Challenger with 787. This spring I found that one of the plugs on my exhaust manifold had corroded through so I removed the manifold and alumiwelded the hole closed. It seemed to be a solid repair.
So I put all the parts back together and even used RTV gasket material.
So the boat runs fine, but after a while of running at 6-7000 rpm I noticed some smoke in the engine compartment and noticed that the exhaust manifold which had been purple was now black (when I heated the other part of the exhaust manifold in the barbeque grill to facilitate the alumiwelding it turned the same color of almost black). The engine seemed hot so I poured a little water on the manifold and it steamed.
At all times I got the little pee stream out the back of the boat which seemed maybe slightly warmer than the lake water. I ran at idle back to the dock and when there I noticed the manifold was cool to the touch and the engine seemed to run fine.
so can anyone tell me what is happening here? is there an obstruction in a hose maybe? did i inadvertantly block something with my welding?
is it possible the boat is getting just enough water to cool at idle speed but not at high RPM?
what next? is there something I can check at the dock without pulling out the boat?
keep in mind that competent mechanics in this area are rarer than winning lottery tickets. Last year the shop had my boat from May 15 until Oct 28 so I am reluctant to give up yet another season to have it sit in a back lot.
