Seadoo-Lover
Hey guys, my damned 98 XP Ltd is making trouble again! - This time it is the cooling system :ack:
Had already the prob that one cooling line got damaged by the hot exhause that melted a hole in it. That was the reason why my rear exhaust-hose-connector (connection to waterbox) exploded. http://www.seadooforum.com/showthread.php?t=26900
I replaced the water line and the hose and flushed the engine. Everything looked great,no water leaks and flush-water came out of site and rear outlets as supposed. Took the ski for a testride and the rear hose exploded again.
This time another water line of the exhaust melted.
Replaced the water line again and towed them up to ensure it wont happen again. I even ordered a brand new OEM hose to ensure it wont happen again this time!
Yesterday ski run great for at least an hour, then I quit cause I had water in my bilge and haven't fixed my bilge pump yet. Wanted to check the rear hose if it is broken again, but it wasn't. Looks like I fixed the prob. Just burned my finger intense when touching the pipe clips cause they were that hot.
Today I took the ski to the river again. Warmed it up slowely as usual and drove it for about 90min with a few stops. Then it started to bug around again. I checked the rear of the ski and saw it was 1/3 filled up with water flushing out of the brand new rear hose! It's broken again:ack:
Checked the front pipe water lines and all are fine this time! Beeper didn't gave me any overheating signal either, so should be working...
I know it is the cooling system. But why does it look like it should if I flush the ski?
How can I check the cooling system? Would it work to try to flush the lines with compressed air, or could I damage anything doing that? Thought already of pulling the exhaust water lines during I flush the engine to see if they work... but am not sure if you can do that?
So please give me some help how I can get these bug fixed.
Thx already forwarding guys!
Greetings from Germany:cheers:
