I agree!
The ECU could very well be over correcting causeing a lot more oil to be used than what's necessary. But I don't think that would explain the drop in the compression like that. I did review your other post about the hot starting, etc...to see if there might be some correlation between those problems and the ones your seeing now in the compression drop. I'll also be waiting to see your next set of results from another test. Do it with the engine cold.
The compression....if you had a drop, say in the center cylinder and the other two were 10 pounds over, then I'd say you might have a bad cylinder and will need to be re-ringed. If you had a bad head gasket, blown between two cylinders, then you might get good compression on one and low on those two, but for all three to be almost equal......makes me want to believe there something else to it......hopefully a bit more simple, just finding it.
I've asked Don, "Wheels and Waves" to come back in and take a look at your compression. He owns a PWC shop and specializes in the Rotax engines, but a mechanic is a mechanic and I'm sure he'll be able to off a little more input as to what we can be looking for.
I did look at your exhaust system and both heads discharge into the center seperated by a baffle plate. There doesn't seem to be anything there that would allow the exhaust gases to cross over to create a compression reading that would be equal.
I have done a lot of reading on the lubrication system. I'm thinking there may be a connection to the way the oil pump is shafted to your crankshaft.
I'll be curious as to what Don's opinion is. Hopefully he'll have a look by tomorrow.
