Previously on As Arkansan's Sportster Turns, my husband and father-in-law successfully replaced the dead starter, and both engines started like champs. But despite plenty of RPMs, the boat would not get above 20 mph. Everyone's best friend, Dr. Honda, asked if there was anything in the pumps, and we didn't see anything obvious. And then we went home.This afternoon we got back up to the boat, dropped down the grates and took some flash photos with the cellphone. One looked just fine, but when I zoomed in on the very end of the other tunnel, I gasped: There was a twist of the nylon tow rope that we sucked up last summer. Thought we got it all out, but apparently not.
My husband pulled off the impeller housing from the back -- he was SO HAPPY not to be standing on his head for this repair. There wasn't much rope, but what was there had essentially fused to some kind of black rubber ring that was about 1/2 wide. We had to cut the rubber ring off in order to remove all the nylon rope.
So what was that rubber ring? The diagram shows a small retaining ring, but this was wider than that. I'm going to try to post the photo of the rope as we found it so you can see exactly where it was. The impeller and wear rings actually look really good. I'm also attaching a photo of the driveshaft. We do have the rubber tip.
