Hi guys this is for the clever ones out there
I have a 2006 155 wake non supercharge
It refuses to rev past 6500 rpm
To date I have
Swapped out plugs coil packs oil is spot on injectors cleaned and checked fuel pump swapped from sister ski that runs perfect new ware ring and impeller (solas 11/19 sister ski runs the impeller revs to 7600) no exhaust leaks in to bilge no fault codes tps has been reset throttle body checked ski starts on the button runs perfect just will not rev over 6500 not lumpy on idle will rev on the trailer to 7500-7600 I have been through every single thing I can think of so and one any ideas if so please chip in
Thanks in advance
To date I have
Thanks in advance
