Challenger 1800 just rebuilt top end, rebuilt carbs beginning summer. Tried to break in new engine wont rev over 3000 and backfires thru carb sometimes, seems to idle fine. Almost sounds like engine is missing. checked plugs couple times one doesnt seem to be firing as well as the other. I rechecked compression after playing with it today still at 150. Could it be a bad coil or does rev limiter have something to do with it. I noticed that every so often I would get some beeps and it would kill the engine right after starting. But this would also kill the good engine to if i had it running at the same time. Any help would be much appreciated
