Hello Guys,
I just got a 1996 SPX from my uncle that has been sitting for a few years. It was used once last year but would not throttle up.
I cleaned the carbs and replaced the fuel lines last night (they were pretty icky).
My question is about the motor though. Before I cleaned the carbs, it would start and run very rough. The engine shakes.
I noticed that the motor mounts are in good shape, the bolts holding the motor down to the metal cross pieces are where the vibration is coming from.
How can I tighten these bolts? Do I have to take the whole engine out? Can I prop up the engine without damaging the drive shaft/pump if I do not unhook it?
If I have to unhook the drive shaft, what all do I need to take off?
Thanks,
Jeremy
Thanks,
Jeremy
