I'm glad it works, just want to be factual.
The donor ski was a 1998 XP in the above scenario.
I believe issue is the term 'coil'. As I haven't opened a 1998 ebox, which has a connector on top (vs only on sides of the 1999-02) it may contain two coils, however the plugs on that one would both fire at the same time.
So it would be correct that it's 'dual coil' however it's still wasting a spark, as it's triggering both plugs every time, which is the only option when you only have 2 points of reference on the magneto. you can't tell the computer anything other than when to spark, so you can't tell it which one to spark, so you spark both.
I'd have to see inside a 98 e-box to confirm.
I should have worded it like this: 951 carb engine:
97.5 to 98 has two long tabs on the magneto, and uses a wasted spark system
99-02 uses 1 long and 3 small, and does not use a wasted spark system
also the 00 or 01 adds a TPS as well, I don't think the 98 has that...
something else to consider for the swap. i think it either does or doesn't show 5v below 90% throttle, then the opposite above. 3 wires, black, white, purple, but it's been a while since I looked at one.
ohh and the 01 added a rubber gasket between the exhaust manifold and pipe to seal better. it uses a newer manifold. those are the ones I run.
