sea doo doo
I have a 97 challenger 1800 with the twin engines. Both engines have been underwater due to sitting up with plug left in boat for a period of time. Got water outta engines, had carbs rebuilt and installed. new fuel lines, new filters, cleaned out baffle and gas tank. Now running on premix instead of injection. Both engines ran good for 5 minutes after carbs were adjusted at local seadoo shop. Engine behind driver runs steady at 3500 rpm after 5 minutes then stalls but starts back up immediately. Actually will stay running if you throttle back before it dies. Brought back to shop to have them check out. They even changed carbs out from one side to the other with no avail. They have advised me that the engine is about to seize up or an electrical problem is happening somewhere. Anyone know my next step before i get upside down in this boat?
