I have a 1997 Sea Doo GSI that i've been working on. It had a bit of a hesitation when first accelerating from a stop and I have the gray fuel lines so I decided I would clean the carb. (I haven't replaced the gray fuel lines yet - that will be next) I removed the carb, took it apart, and cleaned it. I removed the internal filter and it was clogged with sludge. I cleaned the sludge out. I was very careful to keep everything in tact and as It was when I pulled it apart. I put the carb back on and fired it up and the engine revs uncontrollably - I have to pull the lanyard out to keep it from over revving. It heads over 5000 RPM and increases. I figured I had an intake leak causing a lean run condition so I pulled the carb off, cleaned all of the gasket off the intake, scuffed up the intake, pulled the carb back apart to recheck, everything was in order. I reinstalled the carb and it did the exact same thing. (I am using the original carb to intake gasket) I made sure my fuel lines are in the correct spot, I cleaned the inline fuel filter and made sure the o-ring was in tact. One thing I did notice is when I pulled the carb off, the oil pump lever swung all the way around so there was no spring tension on it. I swung it back around until I had spring tension again. Can this cause a high idle? I don't know where else to look. It was running and idling fine before the carb cleaning. Any help is greatly appreciated!
