Engine replacement
JohnK
How difficult is it to replace the engine in a GTX mill. edition? It has the 951. I will just be swapping the shortblock. I'm good with mechanical things but i've never worked on a SeaDoo. Is there anything special I should be aware of? Thanks
get a repair manual and you will need an impeller tool to use during the removal and installation of the flywheel and pto. use locktight on all your bolts!
