BRP still sells a re-manufactured 717 short block as of 2 years ago. Not a drop in. Use your old mag, PTO, head and rotary valve stuff. Cylinders are sleeved to standard and a factory crank. I was going to do just a top end but the crank seals were leaking badly so I went this way. It was slightly more expensive than doing it myself when I added in all the shipping. All you need are wrenches, torque wrenches, PTO tool is nice, puller for the mag, a seal kit and some mechanical aptitude. All OEM, has a warranty, and it was fast since the dealer had one 10 miles from my house. You have to return your core or it is real expensive. If you have a dealer close, give them a call. I did and I was surprised.
