96XP
I don't usually work this way, but since this part required a special tool, I had to ...
I put the impeller back on and started screwing it in (red locktite added), when it got too hard to do by hand, I used the shaft with vice grips
attached. But there is no way to measure exactly 52 ft/lbs doing it this way.
It turns, but is tight. I can turn the impeller by hand, but I need gloves to keep it from cutting me, so it doesn't just spin freely. I just cranked it almost as hard as I could (trying to picture how hard a 50 lb bag of feed would feel hanging off it, so just guesstimating).
How sensitive is this measurement? Will it mess it up if 5-10 lbs over or under?
Can I use slack/endplay to get a better estimate?
Please don't tell me I need to buy the tool...it is over an hour drive to get it...
but I will do it if I HAVE to...
And ALSO...the carbon ring...is it just a mechanical seal that will seal up with water and not lube? I used to use them in the machine shops on some of the stainless steel vacuum pumps and compressors, and want to be sure using no lube will not mess it up.
