justinb
Hi All
Hoping someone with electrical knowledge on a seadoo gti 2002 717 can assist me with some questions I have .
Firstly my motor would not start after rebuilding it , the first thing I looked at was to see if I was getting spark was getting a very small spark .
I then turned to my book,did some following tests
1. Checked plugs they ok
2. I then tested the magneto generating harness the 4 wires by the fly wheel cover.
I tested the black and the red to black cable was getting the resistance within spec 56 ohms .
I even cross checked it with the yellow ones to see if I was getting a short or anything on them nothing showed open circuit .
I then checked Vac across these black cables with my meter ,cranked the motor I got around 48Vac , according to the book it should be between 18 to 25 ? Why would it be more ?
Could this be the reason the spark was not strong on thr plug?
Anyways I then checked the ignition coil took both the plugs off I got a reading with in spec see first pic
I then tested the 2 spade terminals ,see 2nd pic , noticed it's 0.4 ohms above recommended amount ?
Could this be the reason ? Are the high Ac voltage linked to this ?
I then redid the tension cables of the plugs cut it back to see the inside cable then put the plug on , I then re tested cranked it and the spark was triple the size it was .
But still no start , do I need to replace the ignition coil and startor ? Or are those readings fine?
I also figured out why or one of the causes my ski would not start compression on one cylinder was 90 Psi and the other 135 , open the head to find the ring was not seating correctly against the wall .
But that's been sorted , I just want to know that the eletrcial side is or is not part of the issue
thanks all
thanks all
