ECM Issue?
Scott Martin
Premium Member
Premium Member
2000 Islandia suddenly stopped running. Both the Fuel primer pump and the Vapor Separator fuel pump no longer pump with the key on. Both run if supplied a ground. Ran the pump tests as well a validated continuity to ECM via pin 2, which suggest the ECM has finally let go. 2 questions:
1. Are there any other tests I should run before assuming the ECM is bad?
2. Does anyone know of a shop that repair and ECM or if one is available aftermarket?
Thanks,
Scott
Thanks,
Scott
Thanks,
Scott
A little good news--
The ECMs are pretty robust and seldom fail.
As you found, when supplied with ground connection, pumps work. Check all your ground wires. There are several. No green connections allowed. How did the connections inside the round ECM connector look?
The only aftermarket co. that I have heard of is Brucatto (sp?). They can test your ECM and repair if required. The ECM is potted with resin.
