2014 GTI 130.
Out of action for a little while (4 months or so) to fix steering bracket and did oil change.
When I started it up, with seat off, funny noise from drive coupler (between engine and pump). It looked like the rubber hose/seal rotated slightly and there was a small amount of smoke and burning rubber smell. I shut it down, everything looked OK so I started it up again and everything seems fine. Impeller is turning, no noise, no smoke, no burning rubber smell.
Do I need to pull the coupler apart? My fear is if the dampner (I assume they have one, my SuperJets do) is tweaked/bad then it may not work under load (impeller spins now, but will it in the water??).
Anyone ever see this happen? Usually the seat is one when I start it, so it may have happened before and just didn't know it.
