do you need to open the carbs up all the way to do a compression check?
cocacola
I just acquired 2 Kawasaki's to go with my Seadoo.
In the past, I have always done a compression check on a cold engine, but until today....did not know I was supposed to open carbs all the way.
Is that true?
Is there a different procedure?
  • Seadoo 720 (new rings) I am getting 150-153
  • Kawasaki ZXI 1100 with big bore kit 118-120-118
  • Kawasaki STX 900 105-105-105
should I take new readings with carbs wide open?
It surprises me that the Seadoo has much more compression.
Maybe I need to re-ring the 900
Yes, always full battery and throttle wide open.
Do not use the Harbor Freight compression gauges.
The triple cylinders are a little lower compression. You should be seeing 120 psi so the ZXI is good to go. The STX is a little low at 105 but seeing as they ae dead even I would run it and see how it does before messing with the engine.
As always with any used ski tis' a god idea to rebuild the carbs with Genuine parts and check the fuel system so you don't seize an engine.
Perfect! thank you
