My apologies for flooding the forum with newbie questions. Only been a seadoo owner for a month or so, but I've learned so much here! Mechanically, these aren't too bad to work on! So thank!
That said, I'm in the process of doing an engine alignment, and I was checking out my wear ring and that definitely needs to be replaced, however the impeller blades themselves are fairly nicked up.
Just wondering if I should have it done at the same time as a new wear ring. I know they aren't cheap to replace, and I found a shop locally that repairs them for about $50 or so.
Is my impeller bad enough or would you guys just put it back in with a new wear ring and be done with it?
See attached photo.
Additionally, the little metal collar that goes up against my carbon seal has 2 little slits in it...I don't think it causes any issues but, do any of you guys have the same cuts in yours? I'll attach that photo too
This seadoo isn't in as good shape as I originally though when I got it, and I'm pretty sure the previous owner was withholding information. Arghh... but I'm determined to get it back on the water!
Thanks!
See attached photo.
Thanks!
