Fixing to have some work done to mine. Pulled a back rest off and noticed the plastic (for lack of better words) alligator push pins or christmas tree push pins are not typical ones like used in automotive. I have an islandia, don't know if yall's speedsters has these same ones, but if so did you buy new ones and if so where at???? THANKS.
Nothing about this is THAT hard, but its very detail oriented and you need patience. To remove the old covers, you need to get a razor and cut the old stitching. SO far, I have quite a bit of time in it, but I am a student and have some free time. ymmv. Check with the shop and get a price first, I would say if they can do it for less than 600 think about it. You will need about 200+ in materials to do it yourself, plus a lot of time to get the sewing an vinyl installation down. It takes practice.cant wait till it gets a bit warmer i will be doing this as well, i have a big sewing shop down the street that sells about 50 types of vinyl, also already have a stapler, just dont know about the sewing, how hard is it to remove the origional stuff ? how many hours would you say ?
Advance auto/autozone/ ace hardware. Any hardcore, stocked to the hilt hardware store should have em. As well as a autobody supply place. After I bolted my bottom section in, I didnt have a need to re use them, its very solid as is.Fixing to have some work done to mine. Pulled a back rest off and noticed the plastic (for lack of better words) alligator push pins or christmas tree push pins are not typical ones like used in automotive. I have an islandia, don't know if yall's speedsters has these same ones, but if so did you buy new ones and if so where at???? THANKS.
I hope the backs turn out better.
A couple questions. How many yards of green did you buy to cover your 3 seats and trim on the reverse seat? How much white?
Could you just run a single piece across the back seat rather than sew individual seats. The vinyl looks as though you could cut 1 wide rectangle, and cut butt section out, and assemble as you described without the sewing. Your thoughts?
Again, great job!
Mind if i ask? The bottom seat cushions are riveted and the rivet is set down in that whole. How do you replace those rivets. My rivetgun wont put a rivet down in that whole the head isnt long enough. Just curious?
