DISREGUARD THIS POST,BRUTE FORCE AND VISE GRIPS GOT IT,Getting ready to replace carbon ring on drive shaft,single 787
JOHNFLAGG
Ok guys,I'm in the process of replacing the drive shaft carbon ring with all new parts(LARGE CHIP IN CARBON RING)...nothing has been disconnected or unbolted yet,But i have cut the old rubber boot off,My problem is the TOP HAT will not slide aft on the drive shaft to expose the the retaining O ring,I have pushed this back in the past by hand..But now it will not move aft at all to get to the retaining O ring,so as to cut the O ring to continue on removing the shaft,Anyone have a idea what the problem may be?I've searched the forums and didn't come up with anything.Thanks guys
Use some spray like WD-40 and tap it backwards, you can also use a block of wood and a prybar on the PTO. You also need to still have the pump installed.
