Stripped impeller and shaft, shaft rubbing on carbon ring.
TAC
I've got a 2011 GTS. around 350 hours. The splines are almost completely stripped on the impeller and the drive shaft. After I pulled the pump and shaft I noticed wear on the shaft and found it had been rubbing on the carbon ring. Is my engine way out of alignment or did the play caused by the loose spline allow the shaft to float into the carbon ring. The pump was not loose when i pulled it off. bearings and wear ring look good. Wear ring has very minimal and even wear.
Thanks guys
Thanks guys
If the play in the splines has gotten so bad that it allowed the shaft to run off-center then it will wear the seals at a much faster rate.
If your engine mounts are tight, then chances are your engine hasn't shifted.
