Riverfurm
In the process of installing a SBT rebuilt engine into my 97 XP. Engine went together fine. Now it's time to O/H the carbs. Very dirty, I think they had some salt water in them. Took a few hours just to get them apart with some heat from a torch (just broke one screw). Spent allot of time cleaning that white powder stuff out. But the problem is the accelerator pump, valves and hoses. I had to drill out the plugs on the pump housing to get to the check valves and free them up. There is one check valve in line that is made out plastic that I can't get to work. I went to the parts view and found only the hose with a price of $35. So I "assume" that this is an assembly with the check valve.
Has anyone come across this before??? Any thing else I should be looking for while I have these carbs apart??
