WaarrEagle
I finally got my rebuilt 2000 GTX DI back together and on the water. 1.0 hr on the new motor so far. It runs pretty well but I am getting an intermittent maint light/warning at times. No limp mode (i dont think - I have only run it up to 5000 RPM at this point), and no buzzer. It only lasts for a couple seconds each time. It seems that is usually happens at higher RPM's, 3.5k and up.
Per the service manual (attached), it looks like very few codes throw a maint light without any other warning text and do not put the ski in "Limp Home Mode"... only Fuel Lever Sensor, Diagnostic Cap Fault, or High Battery Voltage.
Funny enough I broke the fuel level float and this was definitely causing a maint light previously, but it was a continuous fault. I have since JB Welded the arm back together and the fuel level seems to be reading correctly, so I am inclined to think this is not the issue.
I see a Candoo Pro in my future, but any last suggestions before I drop $400 that I have been trying to avoid? (or anyone want to sell me a used one?)
Is it possible the ski is in limp home mode but I am just not pushing it hard enough to notice?
The battery is several years old but seems to start and otherwise run fine.
