I have two 2003 GTI-LE RFI Sea Doos. They have the same DESS codes programmed in the lanyards and ski, so I can use either key in either Sea-Doo.
One of the Sea-Doos will not start. It will not even beep when the lanyard is plugged in. Both lanyards still work in the other Sea Doo. To trouble shoot I switched the MPEM and the "bad" Sea Doo would run with the module from the "Good" Sea Doo.
OK, so assume either the Module is bad OR could the Module have lost the DESS code? I need a Sea Doo expert. Please help. Thanks.
