Thanks MacAddict... you are very resourceful.![]()
So I do indeed have a Dess Key ? What type of programming do they do on these ? Is it Jet Ski specific? I called the not so local dealer that did not have a clue. These skis are too old. I guess like the Harley Shops the focus on the new stuff. When I asked about a 1990 Low Rider, no one knew how to work on them. Unbelievable.
We gotta stick together for certain. Props to you bro. Much appreciated.
Ha ha ha !! Good stuff. On a side note... I called the local Seedoo shop. $55.00 for the Dess Key and 1/2 hour labor for the programming. Basically about $130.00 If I have any parts you need Mac you are welcome to them.You are freakin McGuyver. LOL
If the heat shrink doesn't do it completely (tight enough) put a zip tie around it. Just make sure you don't over tighten it to the point where it does not come off easy enough.
yip, that's typical dealership numbers unfortunately. Cheaper to send it off for programming and a new key by about 50%.. assuming you don't do the quick fix... see my note's in previous post about dangers of the quick fix.
