JohnGringo
Hi. I own an RXT 215 year 2005.
I recently charged my battery while on the craft and after that I was getting a red light warning not often without any code.
Checking The rectifier I was getting zero volt at the DC part. I've Replaced it with a new one and make a measurement and get 13.5 volts. Using the PWC I get a red warning again in less than 5 minutes with and the new rectifier get bad also.
I did measure the stator, it Shaws. 0.5 - 0.6 ohms and at 4k to 5k RPMs I get 50 volts but at higher RPMs I show also 70 volts AC. Is it normal. What causes the Rectifier goes bud?
Any clue what else to test or measurements I can perform?
Thanks
Thanks
