ckleiman
Any thoughts on why my battery dies after about 60 minutes on the water. Suppose the battery is totally fine (took to auto shop and tested multiple times). Also, suppose there are no major accessory draws on the battery. Why would my battery go from full charge to zero charge after 60 minutes of running. I did however, turn the ignition on/off probably a dozen times. What is the system on the 240EFI that charges the battery while the boat is running? I understand there is no alternator on this boat. Thanks all!
