boudreauxm
I recently came across 2-93' SPX models. They have both been sitting unused for about three years. Before trying to crank either one I cleaned out the fuel tanks, pulled the old batteries, pulled the plugs, etc. One of the two I was able to start and ride with a minimal amount of mechanical problems. The second ski has thrown me for a loop. I eventually found alot of 2 stroke oil in the crankcase and sucked it out as best I could with a vacuum pump. I also pulled the top of the head off to check for rust on the cylinder walls and they look good. After putting the head back on, the engine will turn over well for about 10 seconds (spark plugs removed) then it slows to a crawl, the problem has not changed. At that point I cannot turn it anymore with a wrench, however if I turn it back the other way about 2 revolutions it frees up and will turn over again for another 10 sec or so.It will not turn over at a normal speed with the plugs in. I have plenty of battery juice going to the starter. Not sure what is going on here. Im assuming there is more oil which might be causing the problem. If so is there a way to get to it? Any help would be appreciated.
