Toolanddiemaker
Was wondering if I screwed up by putting blue loctite on all my crankcase bolts. I put the cases together about a month ago and I used three bond 1211 with a roller on the cases and then blue Loctite on all the bolts before I torqued them down. At the time I read some info on not using 515 on the bolts because the manuals are outdated as far as sealants go, and to go ahead and use blue. I just wanted to make sure this was ok before I put the top end back on and get everything rolling again. Thanks
