1995 GTX - Rotax 657
Original symptom - running fine towing skier at the end of last summer, stopped for 1 min, then would only idle - Plugs were fouled with oil
Potential issues: oil pump, rotary valve seal, inner crank seals, cranks case joints
Crank leak test at 10 psi shows 1 psi drop over 10 min -> Pulled engine
Tested oil pump and all is fine (1500 RPM for 60 s ~ 2ml, etc.) no leaks at gear, no dripping with gravity oil feed
With oil pump removed, filled the rotary valve section with oil, put the engine on its side and applied 10 psi to the rotary valve volume, placed paper towel under engine and in each intake port - wanting to see where it is leaking
Oil is coming out of the PTO intake side and dripping from the crank seam between the upper and lower crank case in the rotary valve area (see attached image for case seam leak). So in the end there is an inner crank seal issue and crank case leak.
Question(s): If I replace the crank with a refurbished one (new inner seals) and apply Loctite 515 to the case when reassembling will that solve my issue? Or does a leaking case mean other issues. I would replace the rotary valve seal, block gasket, Mag gasket, and crank end seals as well. Are there other items/seals that I should replace if I am at this level? for example the Mag key? The compression is ~145 psi for each cylinder so top end seems OK. I replaced the top end gaskets last year, but not the rings. I am assuming that I cannot replace an inner crank seal - only option is to get a refurbished.
Thank you,
Thank you,
