I have a 1997 Seadoo GTS with a 717 engine:
So i was having some problems with my jetski and I took the top end apart and found that my PTO piston Rings had a little rust on them so I replaced the ring and then put a new gasket kit on the top end the only thing I didn't do was have the walls honed before putting it all back together. I didn't check the compression before replacing anything cause my ski was not running at the end of last year but now when I got it all back together and fixed my original problem I tested the compression today and the flywheel piston is at 135psi and the PTO piston is only reading 120psi... I also cleaned the top of the pistons to get rid of all the carbon build up, I don't think that has anything to do with my compression problems.
Please advise
Thanks
Chris
Please advise
Thanks
Chris
