mike_tyler
Hello all
I'm new to the forum and have had my 96 Challenger since 99. The boat is probably one of the nicest 1st gen Challengers you will ever see. It's always been covered and garaged and has very few hours on it. It's sat for last two years due to flooding in our area and lake closings. We've had it out twice this season and noticed some hesitation on takeoff. Also noticed it would cut out briefly at high speeds. I thought this would clear up with fresh fuel and problem persists so I plan to take into local Seadoo service center and let them go thru the carbs.
A new additional problem that occurred was what appears to be wear ring failure. UNsure what caused this but we noticed boat would cavitate around 15mph. We nursed it home and after a little research here found large chunks missing out of the wear ring. No apparent damage to the impeller and most all else looks like a very low hours propulsion system. I want to replace the wear ring myself before I take it in to the center for carb work. My questions are, what else should I replace while I have pump out? I know I need to replace the wear ring and the front neoprene seal. Maybe good to do the following
- check pump wear
- pump fluid
- replace rubber shaft seals
