I was about to embark on changing the two fuel filters and one oil fliter but came across the following closed thread from Racereddie
"Default Mercury 240hp EFI inline Directional Oil Filter
Just going through the different Oil and Fuel filters in a 2003 Mercury 240hp EFI engine. In looking through the shop manual it could be read to believe that if you replace the Directional Oil Filter (located between the Oil tank and Oil Reservoir Tank) you have to prime the oil pump. Seems that replacing the filter would not break the integrity of the system from the reservoir tank to the pump and it does not give a method of priming the pump without owning a DIGITAL DIAGNOSTIC TERMINAL.
Eddie"
The suggestion it seems he went with was to disconnect the fuel line and run a premix fuel from a separate container until the oil pump was primed again.
Do I have another option? Should I just leave this one alone? the only reason I am changing it is I have no idea if the prior owner had changed it.
Sincerely
Eddie"
Sincerely
