@novafreak69 Like Tim75 said. I just bought two throttle bodies (different part numbers for throttle bodies but same part numbers for injectors) I needed the injectors. Turned out my TPS was bad too, very very hard to turn. The throttle bodies came with TPS sensors on them, took one of them, chopped the wires (different connector) and just used some waterproof connectors with shrink tubes. All set for under $300 (set of injectors and TPS)
@Tim75 --> After replacing my injectors (got them tested before putting them in, all good) replaced and adjusted TPS, installed all new gaskets and seals. Boat starts up and runs every-time however the RPM will sometimes be 1000 rpm, sometimes 3000 rpm...Tried to adjust the idle screw but still erratic every time I start it. Suggestions?
