Well I cannot explain this well, but the boat is working again. We did so many things so I am not sure I can say any one was the root cause of the issue. however, yesterday I found a very small oil line that goes from the pump to 6 locations on the powerhead very close to where the carbs mount. The one at the very bottom was not connected and the hose was damaged. I have no idea how long it had been that way. I had installed a batter case and charger in that area...maybe I somehow pulled this off...I have no idea. So we had changed out all fuel lines, the enrichment valve and did the carb rebuild to no success. As a last resort a little adjustment of the idle set screw and she fired up immediately. Weeks of nothing...maybe a little sputter and a rare backfire....now started with no struggle. Adjusted the idle back to about 1300 (a little high for now) and took out for slow test and ran better than before. Returned, put the air box back on went out for a longer ride, took it up to 5500 rpm with no issue, no alarms....no problem.
Not thrilled I do not have a root cause since now I am not trusting the boat too much. But seems we are back in business. Thanks to all those who responded here. If not for your responses...I would have given up weeks ago. And the other silver lining is I actually found someone under 2 hours from here who supposedly works on a lot of these types of boats.
