Last summer i bought a 2007 challenger 180 se with everything but the tower for a screaming deal. first thing i did after buying it was build a tower, modeled it after the factory one. im about 200 lbs and enjoy wakeboarding (not too bad) but it seems if i have more than 3 people in the boat all 150-200lbs and i'm on the board the boat has a hard time pulling me (or any one else) out of the water, especially if i'm on the wake skate (smaller board area). the problem is it appears to have lots of power but you really have to feather the throttle or it "breaks traction" and cavitates until you back off and catch the water again. the boat with 4 or 5 people will do 44 mph it has about 35 ish hours on it, i have removed the impeller and inspected the wear ring and it has a little grove around it about enough clearance to slide a piece of paper between the ring and impeller, but mostly i found when it was assembled at the factory the black sealant that was used was really used and had gobbed and dripped inside the intake tunnel, after 5 hours of carefully removing the excess it runs much better but still will suck with3 or 4 in boat and pulling wakeboard. have i just hit the limit of the jet to suck water? how much can any one else load in a boat and still pull a board? i now have it apart again and how do i get the drive shaft out to inspect the seal? and also where can i find oil, filter, supercharger washers and wear ring? (local dealer went under last year)
