daverooster
I may have both a cavitation problem and a power issue. Sure feels likes cavitation but also having power issues. This boat allegedly only has about 50 hours on it (bought it recently with 36 hours and a little over 50 now). When first driving the boat (when I first bought it) before it is really warmed up well it sputters and coughs before gaining full power and planning off. Once fully warmed up and planned off it goes great - speedo said slightly past 50 with one or two riders. I replaced the spark plugs and the old ones were chocolate brown. Over the last week (rented a cottage at Lake Geneva, WI for the week - beautiful lake but a lot of weeds) or so the problem has progressed. I've jumped overboard and pulled weeds out of the intake more then a half of dozen times this week. Most recently while trying to pull a waterskier it got much worse and the boat won't even plane off - with or without the skier behind the boat and we limped back to the dock. Of course I jumped overboard and checked the intake and no weeds. The next morning I pulled the new plugs and they were wet - I cleaned and dried them and the boat would plane but the problem was still there. Once planed the boat seemed to run fine. The impellor/pump seemed perfect when I bought it and i have not beached the boat or anything abusive. I've owened many jetskis over the years as well as boats and I know what cavitation is but this has me stumped because it seems like both. I also serviced the Rave values (boy were they gunked up!). I found a post that took me through the entire process and they are now srubbed clean using one of those green scrub pads and easy off oven cleaner with laytex gloves). Seemed to run a bit better but the problem is not gone. When I accelerate and if the sound of the engine is 'ra, ra, ra, ra,' which should be a smooth continuous sound the sound is very much 'ra....ra....ra....ra....ra' meaning higher pitch, lower pitch repeat, prior to planing off and the rpms are high like +7K. Not sure why it would not plane off at all yesterday. One thing is for sure when you nail the throttle it is not instantaneous GO!, more like no go. Tomorrow is our last day here and then I can pull the boat out and check things out more thoroughly. I was hoping that it might be something minor that I was overlooking so I could get one last day of boating in before my vacation ends. What else....practically starts the second you hit the start button, idles fine...
