(Currently, my carb is removed from the engine)
Ok... I've been working my butt off on trying to get my throttle shaft freed up. I've succeeded in getting the shaft clean enough so that the throttle shaft moves freely. It has literally taken seven hours of carb cleaner and penetrating oil.
Nonetheless, I am curious to know about the tension on the throttle valve spring(part number 2). I'm curious to know how many times I should wind the spring before attaching it to the throttle lever assembly(part number 52). When I attached the spring, there's almost 75% of one full rotation of the spring before it attaches to the lever assembly. I'm wondering if it should be wound twice.
My issue is that the throttle arm has a slow return... If I barely touch the oil pump cable, it returns. I'm not sure about the normal operation of this valve. Should it snap back to idle? Or, is it natural for it to have a slow return to idle?
http://fiche.seadoowarehouse.com/seadooforums/showmodel.asp?Type=13&make=seadoojb&a=172&b=10&c=0&d=-OIL-INJECTION-SYSTEM-W/-OIL-PUMP
