I was rebuilding the fuel pump for the starboard engine, then decided to clean the internals of the carb. I must have gotten the bolts mixed up, as one of the 4 bolts to secure the carb to the block seemed a little shorter than the others,, like an idiot, I cranked it on, likely stripped it and reassembled the carb.
Well, later that day, testing it out, the throttle gets Jammed on the starboard engine (bolt must have came out and lodged into the throttle butterflies). I assumed the cable was caught and messed with it until it functioned properly. (Assuming bolt fell into cylinder). Started starboard motor, ran fine, tooling along at 50mph or so and there is a power drop. Starboard engine is at zero rpm.
Starter won't turn engine, motor is frozen. I see missing bolt as I am disassembling carb to fix.
My assumption is that the bolt fell into the carb and made its way to the lower gears and froze the motor, but I removed the head and I don't see how the bolt could have made it into the lower portion of the motor. The plugs where white, like ghost white, so now, I am assuming that the bolt came out, was shot down the exhaust, then the motor ran lean until a piston froze.
I was prepared to pull the motor, but I am hoping I don't have to. I was going to remove the exhaust, search for the bolt, then pull the cylinders. Now that the head is off, is there a way to tell of the motor is frozen as a result of the pistons?
Thanks so much...
Steve
Thanks so much...
Steve
