Just a quick physics lesson, and reflection on my above statment.....
OK... your plugs. When they spec the gap, there are a bunch of reasons for that. The big one is because of the available firring energy.
So now you say... "So, I want a bigger gap, and when I open it up to .038" it fires fine."
OK, sure it does. But first ask your self: Why do I need a bigger gap? What am I trying to achieve?
If it's to get rid of build up... it's the wrong thing to look at. Heat range to clean the plug. a "Hotter" plug will burn off the build-up. But the "Heat range" of a plug has nothing to do with the spark energy.
If you want to open it up because you think you aren't firring all the fuel... well... unless you are using a MSD type ignition, you only get one chance to fire that jug, and honestly, if you think you have a high speed miss, then closing your plug a little is probably what you need to do.
I Know most of you are about ready to say... "your an Idiot." I agree (that I'm an idiot) but listen to me on this.....
OK... so the spec for your Doo's is around 0.022". When you pull a plug an look at the spark, it really isn't that bright. This is our starting point. So... how does a spark actually occur? An energy source has to create a potential in 2 places. One is a positive, and one is a negative. Now, to actually get that spark to jump the gap, you must "Ionize" a path between them. That will let the little electrons to flow across air. (normally not conductive) So our weak little spark plug can do that while you are looking at it. That's all fine and good, but that's at 1 bar of pressure. Now, in your engine (if in good condition) while running at top RPM's... you probably are getting right around 180 psi in the jugs just before fire. That's about 12.25 bar. So, if we compress a gas, all the little molecules get squeezed together. Normally you would think that's good because the electrons are closer, and you can pass more power. WRONG !!!! it's actually the opposite. Remember, air for the most part isn't conductive, and now you have to ionize a path though 12.25 times the junk. This is equivalent to trying to fire a gap that is 0.260". If you open the gap 0.038", that is the equivalent to 0.466" while running.
So the question is... do you think you can fire a plug with almost a 1/2" gap? (I don't)
This kind of thing comes up on this board every once in a while... but we see it all the time on the Hot Rod, or tuner boards. Guys will bolt on a supercharger, or turbo, and then want to know why their engine shuts off as soon as they see 8 lbs of boost. (they get a static plug gap of about 2 to 6 inches)
