Bow Lights and Instrument Cluster Not Working
sx3indy
While replacing one of the front Bow Lights I put the wrong bulb with too much voltage. The instrument panel and all lights quit working. I checked the fuse....but they look fine....Does anyone have any other suggestions I can try to troubleshoot the electrical issue? Thank you for your help.
Pull the fuse and put a test light between the fuse connections with the rocker switch on to see if you’re getting power to the fuse block. Might have blown a fuse somewhere else. Would also check near back of the battery switch. On mine There are a couple of fused lines attached for the accessory block. Good chance blew one of those.
