bolt Rave valve in the open position permanently?
irishlad
Has anyone ever or heard of anyone threading the top of the rave valve and fastening it to the housing in the permanent open position? I was thinking about doing this since I keep melting assembly. Any thoughts?:facepalm:
Personally... if I had to pick a position... I would bolt it closed. If it was open... you may have a had time getting a stable idle, and you will loose a lot of torque.
But, if you are melting things... make sure the housing isn't too warn, and get good O-rings in there.
Nope... it should still get to max RPM's... but you will loose the top-end "Snap". SO... eventually... it will get to top speed.
BUT... if you have them open all the time... it won't be any fun to ride. You will make a corner... hit the throttle... and it will fall on it's face. The biggest factor on loosing top RPM is really the water regulator.
