I removed the carb bank from our 947 engine for rebuilding. Before I go tearing it apart, I thought to jot down some of the original carb settings.
Now the Carburetor Reference Chart indicates that the 2001 -947 engines should have an initial setting of 1.5X for low speed adjuster; and 0 turns for the high.
Ours for the high setting is one full turn open; and low is relatively the same.
Is this high setting wrong?
What should I expect if I go with the carb setting suggested by the Reference Table?
What would I expect if I leave it at the setting I found ours set to?
