Hi.
What engine do I have? Every one I see has these oil ports at the cylinders.
Ive been searching but cant find any info.
I have purchased a used replacement 210 hp(im told) M2 sport jet(no plate on the engine..how do I identify?) which looks almost the same as my blown 210 but is missing the ports on each cylinder and the ports on the reed block are in different locations. I believe its a 240 block and ive swapped out the crank cover/reed holder block and my carburetors but dont know what to do with the hoses .
I am trying to replace the engine, have removed the oil system and am going premix so what do I do with these ports,hoses? are these ports oil or vacuum ?
Also The port on the block that connects to the pulse port on the fuel pump is a smaller port than what was on the 210 HP (3/16 vs 1/4" ?) so the pulse hose on the pump is too large for the block fitting .(option?)
Thanks in advance for your help.
John
John
