best way to paint a ski
col84
I'm thinking about painting my xp with awlgrip but i cant figure out what the best way to handle painting the bottom of the hull as far as it sitting on the trailer. Any ideas?
Roll it on it's side...then you can paint it from bumper guard to bumper guard, side to side.
Ok looking at the awlgrip site I can't find the color I need. I have the yellow/black 99 xpl and they dont show any yellow even close. Any other ideas?
you have to understand awlgrip is a very nice paint but is limited on some colors, they also have metalics......you can start with a base white/snow white and add your color pigment to it, you can add pigments to achive the color you want, a paint store will be able to match the exact color you want......................As far as painting it on the trailer..good luck....better way is to find a very strong overhead beam and attach to it, I have seen it attached to the front and rear eye hook but do not rec it, Use 2 straps around the bottom of the hull and winch it up off the trailer, then once dry you can move the straps and do the strap areas....now a way I like is if you have a tilt trailer, tilt it up, or pick the entire front of the trailer up stand the ski on its rear rub rail attach a rope/cable/strap to the front hook just to keep it up and remove the trailer out of the way, you will want to put something under the hull to keep it from scratching the new paint when done, this will make it where you can paint the entire ski with moving it around......and It would not be a bad idea to remove the engine as that will take at least 100lbs off the ski, my ski is only 662lbs and around 500lbs or less without anything in it so 2 guys can lift the ski up on its tail without hurting yourselves.
another thing you need to take into account is that is just a color chart, they are much brighter when appiled. the federal yellow is very bright and can be made however dark or light or toned you need, The super jet black is just that, it is very nice when sprayed, these paints do not require clear coat they shine by themselves however awlgrip does offer a clear that you can use over them. A true awlgrip supplier can log into awlgrip and retreive the pigments needed to mix up the paint......just remember you can make any color you want with awlgrip paint it just needs a pigment.
