LeeZeitvogel
So I ran the boat today in the bay and it did fine, and when I go to flush the engine at the house I hook the hose up turn the water on full blast then crank the engine and only run it at idle speed and like clock work it sounds a constant solid warning beep after about 2 or 3 minutes so I get scared and turn the boat engine off, wait about 5 to 10 minutes and crank it again and 2 minutes into the flush it beeps again. It makes flushing for 10 minutes (like the manual says) a timely procedure, plus am I hurting the engine, and is it perhaps not getting enough water, I don't have a clue why it beeps only when I flush, Any ideas?
