Hello, took out bad beeper last year. Didn't get to new beeper till now. Can't find wiring. Any one have pictures of inside beeper wire and connection they can share. Thanks send to poetbruce@verizon.net.
Assuming it is like a 1996, the beeper is visable if you stick your head under the driver dashboard, there is a large hole so the speaker can be heard. Open the driver storage, pull out the bin and you will see a 1" diameter round black plastic thing with 2 wires coming out, just under the steering mechanism. There is polarity to how you wire it, for me I just guessed and checked it worked properly before buttoning it up.
