Bearing
mchinn46
I’m rebuild a 1997 sea doo xp I’m going to replace impeller bearings want to know what tools I will need? Or what press needed for bearing
There is.special tool for this procedure,,however,,you can make your own tool..that is long, thin, and has a lip sticking out to catch the edge of the bearing,,,wha you don’t want to s drive a bearing into the inside of the pump!,!.because it will be impossible to get it out.
