Battery sizing confusion
SkierMan
16C, 16CLB, 16BS, etc. 20HL What is the difference? The post configuration?
Is odyssey HEPPC535 still the preferred AGM for 96XP?
Post configuration and battery type.
The stock battery is a 16CL-B. I prefer the NAPA or Yuasa ones for the flooded standard batteries.
The Yuasa sealed equivalent is a YTX20 HL BS.
So any battery that is equal to those 2 will work.
I still buy the good flooded ones and keep them on a Battery Tender and get 4+ years out of them. In fact I just bought a NAPA 16CL-B today at lunch. $77.
Battery Type: YTX20HL-BS-PW
Height with 20mm spacer included for use in replacing YB16CL-B
Includes 20mm spacer for use in replacing YB16CL-B.
See Battery Cross Reference Chart below.
Voltage: 12
Capacity: 18
Dimensions: 6.875" x 3.4375" x 6.875"
Weight: 12.4 lbs.
Metric Dimensions: 175mm x 87mm x 175mm
Metric Weight: 5.6 kg
Polarity:
Acid Volume: 0.93
Amps: 1.8
C.C.A.: 310
Battery Type: YB16CL-B
Voltage: 12
Capacity: 19
Dimensions: 6.875" x 4" x 6.875"
Weight: 10.1 lbs.
Metric Dimensions: 175mm x 100mm x 175mm
Metric Weight: 4.6 kg
Polarity:
Acid Volume: 40.6 oz.
Amps: 1.9
