Charging system....
You'll need a multi meter for the test. You can buy a cheap one from Walmart.
Charge the battery. Before starting, take a reading. The meter should be set at 20 volts DC. You should get a reading of about 12 volts. Now, start the ski. Read the battery now with the engine running. If the charging system is working, you should be seeing about 14 volts are just a bit more. If you see 15, your rectifier/regulator is shot. If you get the same number on the battery stopped and running, then it's shot.
If your reading is good, just over 14 volts, then take the battery down to your local "autozone" or "advanced auto parts" and ask them to load test it. It's free of charge.
Remember, ski batteries normally last no more than one or two seasons........:cheers:
